- Sep 3, 2021
Enjoy la dolce vita! You've earned it.Now a weekend of rest, with an excursion to the Rocca di Angera on Lake Maggiore with very rich local lunches and dinners ...
Beautiful work Piero. That is the cleanest-looking dory so far!
A slightly different paint job, but very convincing and looking ever so good.Today's update:
I have finished painting the hull.
I also decided to paint the part with the visible frames in black because I like it more and because I can insert the decorations and the plaque with the name on this side as well.
I made the rudder as for Peter's technique ...
See you later!
For a "quick" build, the quality standards you apply are high.Thanks Dean!
For all my Friends, the latest weekly update. All the stuffs assembled and glued very quickly because they have already been made previously.
Ad Maiora Vertite!
She's becoming more lovely every step of the way!Just a couple of pics of the state of the art. I started mounting the deadeyes and the decorations on the starboard side. After this I will close the works until April 26th due to a little vacation in my old city ...
View attachment 303053View attachment 303054
Whenever I see a picture of the bow, it seems to me as if it's too blunt. I think the bow should be sharper...
Nothing to do with your build, or the outstanding quality of your work, Piero, just an observation on the YQ-model itself.
Yep, I checked various sources and I found some controversy on the lines of the bow, see this topic on SOS: https://shipsofscale.com/sosforums/threads/the-schooner-bluenose-plans-discrepancies-which-is-most-accurate.4705. It appears as if YQ has opted for the more distinctive "knee"-shape in the bow.Well, seeing all the old drawings of the first Bluenose and positioning the keel of the YQ model, it seems completely overlapping. Appropriately related, of course.
Have you tried to do the same thing? I did it at the beginning when I assembled the keel ...
Could it be an optical effect?
I think if we get too obsessed with the model verses actual, that we would be better off buying the plans and doing a scratch build.Yep, I checked various sources and I found some controversy on the lines of the bow, see this topic on SOS: https://shipsofscale.com/sosforums/threads/the-schooner-bluenose-plans-discrepancies-which-is-most-accurate.4705. It appears as if YQ has opted for the more distinctive "knee"-shape in the bow.
At one point I even considered changing the bow's shape, but that would open, for me at least, an unsurmountable can of worms...
I think that is most likely one of my future projects, a scratch build! I might as well do it all myself with a good set of plans!
Fair point, although my current capabilities do not lend themselves to jump into an adventure like scratch building.I think if we get too obsessed with the model verses actual, that we would be better off buying the plans and doing a scratch build.
With a kit, they lazer cut pieces for you. Scratch build just takes more time, because you have to cut everything yourself. If you get a small scroll saw, cutting frames would be fairly easy, and you have to sand them regardless. So a kit really just saves time by packaging the wood and fittings, rope, etc. and by pre cutting the frames and other small pieces. I think you could do a scratch build...as long as you can understand the plans, you can cut the wood.Fair point, although my current capabilities do not lend themselves to jump into an adventure like scratch building.
With respect to the YQ-lines, I've come to accept them for what they are, but sometimes, like in the picture Piero shared, it just triggers.
This shows an awful lot better!Johan, this pic is taken exactly "in line" and shows the bow with its curve chosen by YQ. The others were taken at an angle and gave the very noticeable "knee" impression. It seems to me that it is very "blunt" and I do not see the knee ...
What do you think?
Must have been the angle under which the other picture was taken.This shows an awful lot better!
